voyager tire replacement
im thinking of replacing the tires on my voyager kit with 185/60r 13 its 13 years old and has the original tires on it you can see the dry rot if you look deep in the tread just not sure how it will handle with the wider tires anybody tried it sure should look better. Thank sidecarwilly
Tires/Wheels
I had inquired about upgrading my voyager to different wheels or tires and this was one answer I received from voyager.
The 13" wheels can be replaced with 14 or 15 wheels. You may need longer hub spacers & bolts and shorter fender support bracket depending on the one you have.. The 14" are 175/65/R14; 15" - 185/60/R15
Motorcycle Tour Conversions, Inc.Home of the Voyager
Maybe this is somewhat helpful in your decision
Joe Henry
