Voyager Axle Hub
ZED
Jul 5, 2012
42
MT. AUSTIN, TX
Zed
Does anyone know how the axle hub fits onto the Voyagers?, I wan to fit a set of Ford hubs, I am hoping I can just change the hubs over but I don't know how they fit onto the Voyager axle, Photo's would be great if anyone has any.
You may have a factory specific question.
From what I have observed of the kit (did some work on one once,not the axle) the hub appears to be a common trailer type that you would remove as you would on a trailer.Most small trailers have a 1" axle and don't know if a automotive hub would work.
If so,you would remove the dust cover,pull cotter pin,remove axle nut and slide off hub.
Then you can compare your Ford hub for fit.Everything would have to be exactly the same as original hub or or your kit could become dangerous to ride.
Why would you want to change from original hub anyway?
Over here the standard wheels are not a common stud pattern & hard to find, I really don't like the look of the stock wheels either meaning Less choice & harder to replace in case of rim damage, So I want to put a more common set of wheels on..
Joe Henry
