vibration
vibration when i first take off 95 goldwing trike could it be front u join
We need a little more info on your problem.
Does the vibration stop?
Is it a low speed only (like just starting off or below 10mph)
can you give us some idea where the sound comes from?
Is there any noise associated with the vibration?
What ever you can tell us will help.
Regards,
Chuck
Mine does a little chatter if I take off with out enough gas. Only the first 20 feet.
any vibration that is noticable "can" be a problem, u-joint, drive shaft or even a wheel hub, does it vibrate when you decel from say 65? if so it does sound like its in the drive train, in that case,,,,see you installer! check the wheel tightness and check you cv boots if yours have them! bol jmho
Have U had the alternator changed or worked on.???? If so the rubber busings should have been changed. This will cause engine vibration...
Realy need more information regarding when it happens, under what conditions it happens, etc. Any solutions we come up with from what you've given us would be pure guess work.
NM
sorry it took so long to get back it chatters when you let the clutch out slow only noticeable on take off and not all the time i do get a vibration between 65 and 70 no; vibration between gears other than the little chatter taking off in first thanks for all the reply s
the problem of having such a smooth and quiet bike . I once hunted for 10 min while riding for a gingeling noise sounded like a ringing . after 10 min I found it was my key in the ignition .
You may just need to try different oils. Mine had a "shudder" on takeoff, especially on a hill. First, I learned to give a tad more throttle, but the vibe was still there, but less of it. I changed out the Honda Spec'ed oil, and went with Delo 400 LE, and it is virtually gone. It still does it if I don't get on it when taking off 2 up. Hope this helps, jimsjinx
Mine feels better with the Shell Rotella 10W 40 in the Blue jug I get at Tractor Supply or Wally World... 2nd best thing I did to the trike
shawn.s.prescher
