v8 trike question
Oct 8, 2010
Indiana
Hello all,
I am building a v8 trike and have an LT-1 Chevy 350 motor I will be using for the power plant. My question is will I need the COMPLETE wiring harness or can I eliminate the sensors that I will not be using? It is a fuel injected motor. What kind of problems will I run into if I just eliminate everything that I will not be using? Will I need to get the computer re-programed? If so. where can I get this done at? Any info will be much appreciated. Has anyone done this before that can guide me into the right direction for info? Thanks all.
I think you'd have more luck with this question on a street rod forum. If it were me I'd look into either converting to a carb setup or possibly a simpler TBI (throttle body injector - basically a carb replacement, not as complicated as full fuel injection).
On my v6 trike 1985 3800 buick I used only the functions I needed for engine management, used the computer from the car with no problems, can't say on the newer stuff. As trikes4ever said you can get special computer & harness although a bit pricey. Caveman
building a v8 trike, got a 99 cadi rear end. IRS style. chevy 350 power plant. My question is what shoud I use to build the frame with? some one seguseted 2"X4" 3/16"s tubing or I've been looking at 2" thick wall pipe :AGGHH: First time to build such a monster machine. all tips will be helpfull. thank.
Can't help but welcome aboard
Square or rectanguler tubing is easier to get "straight or aligned" than round in my opinion. Now for the computer Might have a look at Mega-squirt system...may be all you need!
I used 2" x .090" wall pipe on my frame & I'm running a 500hp big block chrysler! I have never had any problems with flexing. It all depends on how well you brace the frame. My frame is light enoygh 2 guys can pick it up.
gnsgn1
