Trike Frame Question
Hello All. Newbie question here.
I want to use a Corvair drivetrain for my home built trike. Being a huge Corvair fan is part of it but also because it allows me to have an automatic transmission, which due to my physical limitations is a huge plus.
It may be much easier to find a Corvair engine and transmission that one that the rear suspension is intact and usable.
If I can't find one and have to build a frame from scratch, how much would be involved in using a VW trike frame and convert it fit a Corvair? Are they even close or would it be best to just weld one from scratch?
Thanks for any help.
reply
Big Paul.... I would study your corvair eng/trans mountings, look at the volks trike frames for a reference, and build your own, my .O2 Larry
Thanks Larry, I looked at the frames per your suggestion. By the time I convert the VW mounts to Corvair mounts, I probably could have had a fabricator make the Corvair engine mount portion. Seems if I can have it made for the Corvair it would be far better than modifying another.
Thanks for the suggestion.
I think you can still buy an adapter to mate a corvair engine to a vw trans axle. My bad missed the automatic trans part.
:cool: Glad to find this thread .... there is a mounting plate, but don't know about tranny ..... My Corvair has a Auto .... it may be good .... don't know bought car as is ..... I'll tag along and see how this comes out I started a thread about a Corvair powered three legged horse …. We can combine heads maybe …. :clapping:
cpearson1434
