Trunk light modification help.
I have a 2017 'Wing' and want to change the outer brake light to a brake/running light like the inside lamps. Here is the problem. The plug, the ones that connect to the bulb receptacle, (this bulb receptacle has the standard 3 flat pit connectors), has only 2 wires, brake and ground. I have to connect a center wire for the running lights to work. I would like to use the OEM Honda horse shoe connector to complete this job. I cant find the part number from Honda (shocking), and can't find it on line... HELP!!!!
GL1800 Trunk Light Jumper Wires (EC08012)
Price:$6.50
Item: EC08012 Electrical Connection (in stock)
This is a set of trunk light jumper wires. This kit is mady by Electrical Connection and is designed to utilize the extra filament in the outside bulbs of the trunk lights. On later years of Goldwing GL1800's, Honda disconnected the power to the running light filament in the two outside trunk lights. This kit puts the power back to those bulbs so that all four trunk light bulbs operate as running lights. This kit is made in the USA with OEM connectors and Mil-Spec taps for an easy install. Installation instructions are included and this will fit all Goldwing GL1800's.
GL1800 Trunk Light Jumper Wires (EC08012)Price: $6.50Item: EC08012 Electrical Connection (in stock)This is a set of trunk light jumper wires. This kit is mady by Electrical Connection and is designed to utilize the extra filament in the outside bulbs of the trunk lights. On later years of Goldwing GL1800's, Honda disconnected the power to the running light filament in the two outside trunk lights. This kit puts the power back to those bulbs so that all four trunk light bulbs operate as running lights. This kit is made in the USA with OEM connectors and Mil-Spec taps for an easy install. Installation instructions are included and this will fit all Goldwing GL1800's.
Vthemax
