trunk light conversion
Feb 19, 2008
50
3
Beverly Hills, FL.
Chikie
Purchased a wiring harness to change the outer trunk lights to turn signals. Followed the instructions until it said to look for a connector near the license plate. This is the main connection for lighting on a gl1800 2 wheeler. Well I looked and couldn't find this connection on my CSC. Has anyone else hooked up this conversion from Electrical Connection? I had the trunk all loose and looked underneath to no avail. Any help greatly appreciated. Thanks
Resumed the hunt for the illusive connector today. Found it under the seat and back as far as it could go. Unbolted the trunk and raised it. Then I plugged in the new harness. Ran the harness to the lights and tried them. They work as promised. Whoopie. All is well with extra turn signals.
Thats the biggest bugger when your working on a conversion, things are not always in the place they should be. Good to see you managed to hunt the elusive connector down.
Vthemax
