Trike won't start
Got my 2008 goldwing with 33000 miles trike 3 months ago haven't got to ride much yet went to start today turned over fine gut wouldn't start acts like no fire check fuses they were fine its has never had this problem before just don't know if it is something with kit or something else it's a csc viper kit any idea where to start thanks
Pull a spark plug . Wet … no spark . Dry…… no fuel .
It’s a start anyway , not guaranteed !
Roger .....Welcome To Trike-Talk.....:wave4:.....Setting for 3 months..Throw a charge on the battery, And maybe also check to see if you have enough gas in the tank??
Battery is charged and good pulled plug there is no spark I think it has something to do with the wiring due to the kit installed going to try to talk to the installer tomorrow maybe they can help
Crazy as it sounds check and see if the kill switch is in the position…All when the trike was a two wheeler there’s a kill switch on the kickstand and sometimes the installer will just tape it back and not disconnect it?..
Check the kill switch on the right side cluster on the handlebar, could have been bumped and now off.
I would pull the seat off & look for sign's of Mice in there eating up the wires ? You rode it to were you parked it ? Can you here the fuel pump run when you turn the key on ?
Boatpaddle
