we make it through the hurricane and clean up. i put a couple of hundred miles on and it seems fine now. i think the new fluids had to heat up and break in. thank everyone.
Glad to hear.…Sounds too simple but hey if it works…..
Can you explain this?
This makes no sense at all, fluid warming up should not be a fixing type issue for the problem you originally posted
If you ( as in your original post) were actually in neutral, the only way your trike could roll forward is if you were on an incline, pulling the clutch in would not make the trike stop
There has to be more to the story
