2013 Triglide, all stock. Considering the PV-1 from FM. At some point I will add slip ons and high flow air. Want to install the PV first and see if it wakes up the Trike. If satisfied move on to air flow. Does this approach make sense? Should I do air flow before slip ons or the other way around? Would the PV be overkill on Stock Trike if I decide not to do anything else?
Also, I have the FL-Xieds. I assume they would need to be removed before adding the PV-1?
Are there specific maps for the Trikes or do you get a map built for a touring bike?
Thanks for the help.
