I have seen the specs for the overall width of the 2011 tri glide listed at 43.9" and 54.7". What gives? Is one measurement the track?
What is the track of the tri glide?
I just measured my Tri [11] I don't if I'm measuring from the same spot that the factory measures, But from the outside of one tire to the outside of the other [not the fenders] i get 50 inches??? :Shrug:
I don't know stuff, but I have common sense. You guys are making something hard out of something so very easy. I would suspect the track is measured from the center of each tire. So take your 50" and substract approximately 3" from each tire, that would leave 44". Now If I knew how to use a caliper, I could come pretty close to the 43.88 that Harley shows as the track. Hope this helps.
You just spoiled a half days WORK in the shop.ThumbUp
You should know guys need humored, we like to use tools and sometimes take the long way around the problem, gives us more time to drink beer while solving the worlds issues.
It's Friday the 13th. I just saved you from possible injury while fumbling around in your garage!:wave4:
I'm so glad you explained that, Mike! It clears up so much about what goes on at my house.......... :Coffee:
