2013 Tri Glide Wiring Woes
Feb 18, 2025
3
9
Vermont
Christian
I recently aquired a 2013 Tri Glide (FLHTCUTG). I am guessing the tour pack is either after market or was bare bones and never had lights or passenger speakers. I am trying to install lights and speakers on the tour pak, however after further review it looks like someone cut the connectors off underneath the seat. I believe there was supposed to be a white connecter towards the back under the seat on both the left and right side but all I have is what is listed below.
Wires on the right side
Violet w/ Black
Orange w/ Black
Pink w/ White
Gray w/ White
Green
Light Green w/ Brown
Wires on the left side
Brown w/ White
Brown
Pink w/ White
White w/ Brown
Violet w/ Black
Gray w/ White
Any help would be awesome.
That is a shame. I never understood why anyone would purposely cut off connectors. If they are not going to be used, just wrap them or tape them if you feel the need. It just makes it harder for the next person down the line who wants to add items.
Violet w/ Black
Orange w/ Black
Pink w/ White
Gray w/ White
Green
Brown w/ White
Brown
Pink w/ White
White w/ Brown
Violet w/ Black
Gray w/ White
They don't show Tour Pack but the wire colors you can use.
Violet and black has been turn signal wire colors for years. As far as the other wires I would start with a test light, then with the ignition on check for running lights, then rubber band the front brake lever down and check for brake lights. Once you get the lights figured out you should be able to use a cheap speaker to determine what wires are for your speakers.
Violet w/ Black
Orange w/ Black
Pink w/ White
Gray w/ White
Green
Brown w/ White
Brown
Pink w/ White
White w/ Brown
Violet w/ Black
Gray w/ White
UPDATE - After a lot of digging and looking at some earlier model year wiring diagrams I was able to figure out what the wires were for on each side. I appreciate all of the help as some of the wire suggestions were dead on.
Thanks again!
dhinzman1
