Tri Glide Reverse System Diagnostic Tips
MDO
Oct 11, 2017
5,098
3,143
St. Louis, MO
Michael
This is from the Fix My Hog website. I would suspect this applies to the Freewheeler also.
This month, we continue by reviewing a preliminary, basic, diagnostic overview for determining reverse failure on Tri Glide models. Much testing can be completed with, only, a test light and a multimeter. However, a factory Tri Glide supplement manual and a breakout box is also necessary for complete diagnostic testing.There are four DTC’s that can arise for reverse failure. These codes are #s
P1772 – ECM terminal 4 is shorted to ground
P1775 – ECM detects an error within the reverse system(this one is rather vague!)
P1777 – ECM terminal 16 is shorted to ground
P1778 – ECM terminal 16 is shorted to battery + voltage
The reverse system may not properly function if battery voltage is less than 10 VDC (volts, DC). It is best to connect the battery to a charger before and during the performance of any diagnostic testing. If the motorcycle does not start and run correctly, the reverse system may not function properly. Trike rear wheels should be safely lifted off the ground with jack stands beneath the rear axle before performing any diagnostic testing that requires depressing the reverse switch.
It is important to start with these preliminary inspections:
Check all fuses
Verify that battery is fully charged
Verify that the charging system is functioning fully & correctly
Trip and reset the 150 amp circuit breaker
Note: when the trip push button is depressed, the reset lever should extend out
TO RESET, press the reset lever toward the circuit breaker body until an audible click is heard and the lever is fully seated against the circuit breaker body
If the circuit breaker continues to open under, only, light load conditions or the reverse motor will not correctly function after resetting the circuit breaker and resetting fuses, move forward with diagnostic testing per your supplement service manual.
This testing should include:
Reverse enable testing
Backup light testing
Reverse actuator testing
Reverse motor testing
Circuit breaker testing
RCM solenoid control circuit testing
Reverse switch testing
Ground circuit testing
Neutral circuit testing
Accessory circuit testing
I hope this helps someone. I also hope I never need it.
Thanks Jack. Have you ever used a breakout box on a Harley? I didn't know what it was, so I Googled it.
If the Mods approve, maybe they can make this a sticky.
Not on a Harley, on cars and trucks yeah
I have a friend in Daytona that builds them, not cheap but very reliable;)
I'd love to get my greasy little hands on a breakout box.They come up on Ebay now and then.Pricey.Of course you need the cables and overlays or the box is useless.Ive used a DVom with backprobes on my '09 and '14.No dont use paperclips,needles,or other weird crap some of these yingyangs on the internet suggest.
Short out an ECM/BCM to save 50 bucks is stupid.Nothing says STROKEJOB like someone that uses piercing probes. Kick that guy in the nuts.Had breakfast with a hand at the Flying J in Oklahoma City.
He told me an indy was trying to find an open in his Dynas main harness and pierced about 3 dozen holes then sealed em up with crazy glue.About 6 months later he needed a new harness cause the boy wonder missed sealing up some holes and moisture got in there.Yeah kick him in the nuts too.
​If you've gotten to the point that you've determined your reverse motor is shot, skip going to HD for a new one and take your old one to a local electric motor repair shop. The repair shop will rebuild it for FAR less than HD charges for a new one.
PC
tony29
