Transmission Speed Sensor Connector location
Dec 12, 2010
6
Redmond, WA, USA
Hi,
I have a 2010 Tri-Glide and did the 30 tooth sproket change and added Woods TW-555 cams. Love the change in the trike. The speedometer is now off more than I like and have purchased the Dakota Sim-1 adjustment module. Where is the 3 conductor connector from the speed sensor. I have looked all around and have not found it. Is it under the battery? or where? Or do I have to splice into wireing harness?
Thanks,
Craig
Sensor is behind the oil dipstick on top/side of the transmission just follow the wires till you see the connector
These are the 2 wires that connect to the sensor, the sensor is behinds them. I had them unplugged in this picture to remove the cap from the starter solenoid.
Craig, You're lucky you don't have a 2012 103 incher, that speed sensor requires the removal of the starter motor to get to it, I think. What was the moco thinking?
Phu Cat
Hi,
Thanks,
Craig
Unless Dakota Sim-1 has changed their product there is no need to mess with the sensor. Wire the Sim-1 directly into the ECM wiring harness.
I did this PDF wiring diagram for my 2007. Should be the same for your TG.
Blue Trike
