towpac instratrike wheel alignment
After initial installation and Everything is good. Is it Really necessary to check Again if you dropout and Rehook?
I checked mine every other time. Remember, you have a lot of u-bolts/bolts that can work loose.
It's only aligned as well as it was from after your last ride, which could have changed something.
I just reinstalled mine after riding on 2 wheels for a while and for some reason the right side was off by nearly 1/4 inch... I must have hit a good size pot hole or something before I removed it before... The left side was still dead on...
It's probably a good idea to check it when you re-install it just to make sure... It obly take a minute to check...
I simply bungee a piece of 3/4" alumimum channel to the outside of the bike wheel and a bungee a piece of 3/4" square aluminum stock to the outside of the trike wheel... Then just stretch a measuring tape across and check front and back dimensions...
Les
towpac instratrike fender bra
I called factory and they do not have any fender bras
to protect from stone and rock. anybody know where
I can get such a thing?
thanks
If your wife has a sewing machine have her make them for you... I'm trying to talk my wife into that very thing...
Les
nmbr1soonerfan
