Time for a Fluid change?
Sep 3, 2015
31
6
Dallas, TX
Mark
I only ride about 2-3 hrs each year. Should I do a yearly fluid/filter(oil, radiator etc) change. It has been 2 years since I last had the dealer do a fluid change. I may just have the dealer do a fluid check this year with my yearly state required inspection. Thanks.
Thanks.
All great advice. I just checked with my dealer and I have had no fluid changes, only fluid top offs in the 3 years I have owned my 2001 Goldwing Trike. Yikes. I will have them do a complete fluid change with the inspection next week. Should I do transmission too?
Since you didn't specify which fluids you were going to change, I am going to recommend that after three years you have the brake and clutch fluids replaced. Brake fluid is extremely hydroscopic and has probably absorbed some water.
Note: you really are not riding often enough to keep tires, all rubber hoses, etc. lubricated. If at all possible set up a 20 mile course and take the time each month to drive the trike over that course; less than an hour. Sitting is the worst thing that can happen to mechanical equipment and your Gold Wing is no different. Just my .02.
Mark, get the service all done and ride that rascal to Kerrville for our TrikeTalk meet and greet the first week of October! Hope to see you there.
Hey Mark. Did you have the brake recall completed a couple years ago? If so the dealer was supposed to do a total brake system purge and fill after replacing the rear master cylinder. I'd suggest you still have that fluid checked to see if it's become contaminated.
Setting up a scheduled longer ride once a month is a VERY GOOD idea.. :xszpv: :xszpv:
Jurgen0419
