Champion s/a fluid change.
I an not sure about the SA, but I changed the fluid in my IRS this past weekend, and it was real tight getting at the top fill plug to remove it.
I took a 1/4" piece of soft flexable tubing like they use in fish tank air lines about 16 inches long, and glued a short piece of 3/8" tubing on one end for the bottle of Mobile-1 75/140 fluid cap to fit into. I snaked the tubing between the frame and fender into the fill hole. It worked real good.
2006 Goldwing champion trike
Looking for advice how to check differential fluid on our trike. AZ shop bills 3-4 hours labor to change fluid Ouch ! Hard to believe.
Champion used about 3 different mfg for their axles.I think most of the last s/a were toyota.There will be a check plug no matter who's it is.Mine was right on the back and the drain on the bottom.
Thanks Rhino & Marc. Champion AZ says you have to pump old fluid out and new fluid in which seems to align with some of the old posts Ive seen. 3-4 hours labor is significant which tells me they have to dis-assemble much of the top end for access ? Tks. Tom
attached pic below,, not sure if I did it correctly
I think yours is IRS not S/A so disregard my post.The post above your first from ramknight sounds like an option.
Jurgen0419
