switched positive power source
Apr 6, 2018
11
7
Port St Lucie
I'm Installing a hog tunes system to Memphis shades fairing, all seems ok with the exception of hooking up a orange wire to a switched positive power source, can,t seem to find in manual or you tube, can some one help
On both front sides of gas tank you will find a white connector that is used for running lamps on the RK. There is a power wire and also a ground wire in that connector which runs off the ignition switch and is a fused circuit. You can tap into those wires before the connector or do what I did was get the other half of the connector and the terminals from the dealer and plug your made up harness into it. A 12V test lamp will insure you have the correct wires. That is what I found on my 2019 FW.
Could you please update your profile. It's says you have a 2013 Triglide.
shawn.s.prescher
