It’ll get better
or worse:wave4:
or worse:wave4:
Been quite a long time since last post. We have been riding our tails off during the COVID pandemic. Mostly local rides of 200 to 300 miles but a few weekenders included. Today's ride ended after only 20 miles with ANOTHER broken belt. Just like before, the belt ripped straight across. After the second belt broke I checked and rechecked the pulley alignment and found them true to each other. Checking the sides of the belt for glazing shows black rubber and nothing unusual. Can't find any spots if a rock or debris got caught up in it either. One thing I have been going over is the deletion of the Cush drive. The trike conversion I designed didn't include it due to space issues. These belts are expensive and require removing the swing arm to install. Not an option on the side of the highway even if I did have and extra belt. So I am considering going with a chain drive. Should that break, I can repair or replace it on site far easier than a belt. Not worried about fitting the toothed sprockets as I will machine adapters for them. To lower my RPM's at highway speeds I looking towards 27 tooth drive and 54 tooth driven. I am aware chains require a cleaning and oiling every 1000 miles (max), but I can accept it. Any thoughts or advice on a belt to chain swap?
The O Ring chains need NO oiling. But I would think a chain tensioner, similar to a 10 speed bikecycle would be needed to compensate for swing arm movement :Shrug:
