I put an AIM VPC in my HD VROD trike and to be perfectly honest I don,t feel any difference in the clutch or the levers. I may be the hydraulic setup or something else. I never had a slipping problem but the clutch lever is hard to pull. I also hear the bugger turning sometime. I did not put in any extra washers when I installed the VPC. interesting concept though. curley.
My Aim VPC is going bad after a little over 12,000 miles.
I heard of others having problems with the VPC so yesterday I removed mine and sure enough there was what I consider unacceptable wear. This had caused me no problems to date but I am sure they would have been soon in coming.
I replaced the stock componets and am waiting for delivery of the new ClutchWiz from tglidestuff.com
In the two pics the white pencil points to grooves worn into their spring plate by the fingers, the brown one points to wear on the steel bead on the back side of the VPC , mine was not too bad yet.
I also found that behind the clutch spring plate it was packed with fine metal dust, a lot of it, this was from being spun off by centrifugual force and trapped which is why I didnt notice anything when I changed the primary oil at 10,000 miles.
You cant see this wear unless you remove the VPC which is easy, just take off the Derby cover like you would for clutch adjustment and remove the six allen bolts holding the VPC on.
Is there actually a groove worn into the wear plate and the steel disk of the VPC, or has just the anodizing just worn off on the steel disk? I had around 15,000 on the 84T I removed from my Triglide and 30,000 mile on the 83T I removed from my 06 Ultra before I installed the new clutch with the 92T on top.
Mike , the spring plate ,(white pencil) had definite groves on each finger you can feel with your fingernail, The bead on the back (brown pencil) is wearing flat, no longer rounded and would guesstimate 20 to 30 thousants down , this is where all the metal dust came from.
When I removed the VPC the clutch spring dropped down, thats when I saw what looked like another ring of metal on the pressure plate radiating out about 1/8 to 3/16 of an inch, when I touched it I found it was fine metal dust about 1/32 inch thick all the way around. I didnt think of taking a pic at the time or saving what I took off, this all came from the bead which is wearing flat on the VPC. Its was suprising to see that much there and only a trace on the drain plug magnet.
I didnt notice any other damage or wear but as soon as the ClutchWiz gets here I am going to pull the primary cover and clutch pack for a good inspection and cleaning.
Mr wizard or VT, I just bought a clutch wiz, and am reading about the aim. Will it work with the clutch wiz., or is the clutch wiz part of the mod? Thanks...
ultra boy, I have a 2007 flhtc , converted to trike with a stock 96" motor. just had my clutch replaced at HD dealer about a month ago. I am not sure what they installed but it seems to be working fine but I would like to be sure down the road that it will not slip or worse. I am planning on changing my tranny sprocket to a 30 tooth and I am not sure that will make a difference as to which vpc I should install. please advise and I will order one from you guys right away.. thanks a lot Dan
msocko3, if I just replace the spring for now would that prevent any chances of clutch slipping until I can get back home to Fl. in about 6 weeks from now? I just had a clutch replaced by a HD dealer in Pa. but I do not know if it was a heavier clutch than stock or what and also don't know what size spring they put in, I do know they replaced it with a Harley clutch. I don't have any problems with it now and it seems fine but I like the idea of no slippage or burning out another clutch while I ride it up here in Pa. in the mountains. what do you think?
