have 08 gl1800 motortrike only starts in neutral, when first got it could start with clutch pulled in, any gear. help:xzqxz:
Shoot a little WD40 on your clutch switch, it is likely stuck.
Clutch switch is stuck, bad, or not engaging. Have you changed grips to an oversized set? If so, the clutch may not be depressing enough to make the contact. Listen closely when you squeeze the clutch. You'll hear a small "click" when you begin to pull it, and should hear another as the lever reaches the grip.
