Swan? I don't know, but it sure is ugly.
Let me introduce you to my helpers. You will see two young men in my pictures. They are Steve and Dale. Steve the older brother lives in the next block with his girl frend and kids. Dale lives next door to me, with his parents.
They show up about 6:30 every evening and love the garage.
Last night we got the motor off.
There was no drain plug for the oil, Just a plate with 6 nuts. so off it came and on the plate was a 1/2 " thick layer of sluge. nothing came out. A little scrape with the screw driver and a trickle of water started. Clean water. Then came the oil and it really didn't look to bad. Strangely enough it wasn't milky at all the oil and water were not mixed and stayed separated.
The crank does not turn. Could be the rings are stuck, lets hope.
Wayne you got a great project there keep the pic's coming.That PB Blaster is some great stuff I use it on all my rusted nuts and bolts before I even try to take them apart!!Good Luck & Happy Building!!!
The heads are trashed I might be able to rebuil them but not today. I found an outlet for used parts yesterday so I will have some used new ones.
I moved the shifter back 30"
while I was at it I found the main shaft to be kind of loose so... There is a trany rebuil kit avalible for about $130.
The shift shaft isn't purfectly stright so I think I'll cut it back out and set the box in a bit.
Beautiful
Look what came out of #1 cylinder.
the pistons where solid in the jugs so I had to break them out with out screwing up the cases.
Wow!!! That is a LOT more work then I would want to take on. I'd be lost.
I will be looking for your progress. I'm curious to see your finished product. Good luck.
It is fun trying to figure out how things happen. Like the 3/4" of clay in Number 1 cylinder. The cases are salvagable. The heads can be rebuilt. Not that at this point I will use either, we shall see. The story that I got was that this buggie ran when it was parked in 1985. Not well I'm thinking. The transaxel is worn out the points and rotor are burnt. The plugs looked very rich. We Can Build It.<br />
I will try to make some progress this week but I am putting valve guides in my shovelhead and this will be number one priority for a couple of days.
Durning the week I got the cases apart. I learned mega about VW engines. the distributor drive was frozen, so the pinion gear and th cam gear got wiped.
Everything was stuck, but I think that the cases are OK. It seems that all stock std. bushings and bearings can go back in.
I started on the frame I have 750 that has a titled neck, Sooooooooo, I cut the neck. The motor goes to my son for his chopper project.
And this is My Mistress. ( Wife named her).
There is more frame done now, I'll get picts up soon. I'll tell you what after building the shovelhead, the prices for VW parts is easy to take.
Frame is painted and new brakes are in a box in the living room. I think by saturday I'll have it sitting on three wheels. Picts to come. After doing the math on parts and time I think it would be wiser to buy an engine.
Today is clean the trany day.
Then I'll start the forward controls.
I'll try to take more pictures, I get so dirty that I don't want to touch the camera.
I'm staying in Ohio 3hours from my toys. I'll be going to Pittsburgh maybe Sunday I'll measure it. It is short. The pan is heavy and I put a gas tank between the pan and the frame to add a little weight. With a 200lb guy sitting in the seat .no fuel I can just bearly lift the front end by the axle. Im thinking wheely bars,lol It will be fine I have room for ballast.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
