Stallion Specifications
I have tried to get into the specs on the Stallion web site but the technical data link does not seem to work. I test drove a new Stallion today and needed to get some measurements that I completely forgot about. Maybe someone has them.
1. The measurement from the tip of the fender to the end of the trike (don't worry about the hitch or pipe)
2. From the ground to the bottom tip of the fender in front of the tire.
3. From the middle of the front tire to the middle of the back tire. (wheelbase)
I was just wondering if my existing trailer that I use for my GL1800 will hold the Stallion. The reason for measurement #2 above is to figure out if the chock will hit the bottom of the top of the front fender.
I asked similar questions....
1. The measurement from the tip of the fender to the end of the trike (don't worry about the hitch or pipe) 130" Their advertised 125" is from the back to the front of the front tire. The front finder extends another 5 inches.
2. From the ground to the bottom tip of the fender in front of the tire. 20"
3. From the middle of the front tire to the middle of the back tire. (wheelbase) 98"
Give or take an inch.
Monkie,
My figures are very close to WildBill's. The 20inches was the same.
HLG
