Stallion front axle seal
May 20, 2008
20
2
LONG ISLAND
Damaged inner wheel bearing seals #11353
seal seems too small in circumference and when inserting the axle i hits and damages the seal and will not pass through. Anyone have info or suggestions on how to install the seals and wheel bearings. A diagram or sketch? So far two bike shops have been unable to
fix the problem. It has been out of service since
nov 2027 . It is a 2008 Stallion # 377
It's not the seal, it's the outer edge of the axle. It needs to be slightly beveled on the outer edge so it slides thru the seal. Grease the axle before putting it in. This works, I know! Tomg
+1 on Tom's reply. if you take the take the whole assembly apart you will what Tom is talking about. Making sure that the axle is WELL lubed and smooth. Careful alignment will get it in.
To deal with the problem you have encountered, I had a dummy axle made which is exactly the length of the thickness of the wheel w/seals and bearings. I can assemble
the bearings and seals with the dummy axle in place, roll the wheel into position, then use the oem axle to push the dummy axle through.
Bearing seal
Thanks for the reply’s. Using a dummy axel sounds good but have no idea who could make me one. Not even sure if I have right parts. Can you sketch how to assemble. Is this correct sequence and parts - inner seal cr 1135 - bearing 32006- race- seal national 470025. Starts with inner seal and works out.
So far damaged two inner seals trying to mount the wheel. Have ordered replacements again .
I think you have the sequence correct.
I just went through the same issue, destroying seals. I was able to get it together by putting the axle through the inner seal first, setting the hub / rotor on the wheel, then slide the other hub onto the axle. Once together, the axle will slide side to side to get it on the bike. With the axle through the inner seal first, you don't knock the spring off or tear the seal. Just grease the crap out of the axle first.
parts list for front end.
I found this list of parts for front, rebuild.
FRONT LEFT HUB ASSEMBLY PARTS TMFS-00030
No.DescriptionQTY PER HUBUNIVERSAL PART #
MTGH-0433AE-CLIPS 5/8 BOWED10
TMFS-00420FRONT CALIPER BRKT SNAP RING1
TMGH-006505/8 SPRING/WAVE WASHER20
TMBR-00240FRONT BRAKE CALIPER1
TMBR-00270FRONT BRAKE CALIPER BRKT LEFT1
TMBR-00300FRONT BRAKE ROTOR1
TMBR-00310FRONT CALIPER PAD RETAINER1
TMBR-00320FRONT BRAKE CALIPER BRKT BEAR2$11.50 each 6814-2RS, 70mm X 90mm X 10mm123 bearings. 1 646-712-9672
MTBR-0182AFLOATER PIN-BRAKE ROTOR10
TMFS-00170FRONT HUB (FOR INNER SEAL)1
TMFS-00180FRONT HUB OUTER SEAL1CR14939 OR NAT4706251.5" X 2.22" X .313" measurements
TMFS-00190FRONT HUB INNER SEAL1CR 11353 OR 472644 (NATIONAL OR TIMKEN) 1.125" X 2.047" X .313"
TMFS-00210FRONT AXLE BEARING1HR32006XJ - NSK$18.38 each
MTGH-0434AFRONT BRAKE ROTOR WASHER 5/810
TMGH-012869/16 SAE FLAT WASHER Z/P2
FRONT RIGHT HUB ASSEMBLY PARTS TMFS-00020
TMBR-00290FRONT BRAKE CALIPER BRKT RIGHT1
TMBR-00320FRONT BRAKE CALIPER BRKT BEAR26814-2RS
TMFS-00190FRONT HUB INNER SEAL1CR11353 OR NAT472644
Rear Brake parts, Ford 500
The bearings are from France so there is $24 shipping
Flyboy7312
