stallion flag how????
Apr 26, 2008
62
10
So Cal
Jim
i want to fly a flag behind my putt is there a way to convert the ball to a square to accomadate pole.its for patriot guard purpose
I have never seen the hitch for a Stallion, but if U don't have the square piece to slide in, just take the ball off and bolt a square piece onto it so U can put ur flag pole on it...
There is a way, and someone on here will have a better idea than mine,,,,
Good Luck....
jimc, I would get another hitch from TBMS and then weld your square tube to the top of the hitch for your pole mount. Then you just change the hitch when you need to.
today i bought a 2 inch hitch and had it weldedi also picked up a sport mast came with a 3x5 flag what a deal with my paint job my pony looks bad im a happy camper whole deal 100 bucks
PICTURES!!!!! Your <span class="highlight">Stallion</span> with the paint and the flag...we really need pictures for Veterans Day! Jim, if you want, email them to me and I'll reduce them and post them for you.
:d had a buddy build me one using 11/4 od squar metal and the top was 11/2 aproxamitly 8in
took the 11/4 8in cut inside 45 drilled a hole 3 1/2 in down to place the retainer pin a pice 201/2 same cut and a pice 18in
cut the same welded corners placed a 71/2in 11/2 od pice over and welded placed pole in and drilled a hole to secure flag pole pole was old wooden closet pole worke good and you can still open trunk:d
WHEN I FIRST PULLED UP THE OTHER GUARD RIDERS WAS BAFFELLED
You might check out the following link: RIVCO Products, Inc.- Manufacturer of cruiser and touring motorcycle accessories for your Harley Davidson motorcycle, Honda Motorcycle, Yamaha motorcycle, Kawasaki motorcycle, Suzuki motorcycle, Triumph motorcycle and Victory motorcycle. then include flag poles and mounts in their search category.
Daydreamer
Trike#1
