stallion calipers
Good evening
I rebuilt my front calipers, got a rebuild kit from tbms.
there are 2 cups on each caliper each cup has a square cut rubber ring
and the other is just a regular round o-ring. I found that both the bottom
cups had a lot of water in them and took a lot of cleanup to fix. other than that
it is a easy rebuild. there was a mention in a post many years ago that
they didn't know what the bottom bleeder was for. it is to drain the water from
the system
Good luck
Dragon
hopefully someone will chime in with the info. I had thought someone had posted the info on the manufactory replacements info a few months ago but it could have been just the pads
I believe it was about the pads. I have only read the post about the person that bought the kits from TBMS to rebuild his calipers. I have read that the calipers were made for their application but can not verify that. The pads are available but no info on the calipers and kits.
Dieseluladstron
