Sick Trike
Mar 23, 2015
2
urbana, ohio USA
2012 tri-glide 61 days from purchase date and I find the rear axle drive pulley is loose.
Anyone have information on how this is bolted up, or where I can get a drawing that shows it?
Google up Ronnies HD, and go to the Parts Micro Fiche;; Punch in your year and model , And you'll see All the diagrams you'll need...ThumbUp
Is your garage stocked with basic tools? You may find that doing your own wrench work is not only good therapy but you also learn a lot about your ride.
Get a Clymer's repair manual online for about $50. It is well worth the money. Over the years you will save a bunch of $$$ by doing maintenance yourself instead of paying the dealer.
its really loose, I see wear marks on side of pulley. cant tell if there is a lock ring that holds it in place?
The best money you can spend is on the service manual and the trike supplement, there is movement in the pulley due to the rubber isolators. In the manual it tells you how to check the wear of the isolators.
craneop63
