KDHUFF
TOI -Virginia
I think you are still out of adjustment, sometimes it takes a while to get it right
Do you have a picture of the block tab you are talking about I just got a trike and don't know any thing about a VW. ThanksBy the way, when the shifter problem is solved and you are ready for final installation you might consider if you want to cut (grind or otherwise) that reverse block tab off the plate (the one that makes you push down to get reverse). Depending on the location of your shifter, most VW trike builders find it easier to not have to push down to get to reverse. There really is not much 'gear grinding' once you've shifted a few times and gotten used to it and the easy access to reverse is a blessing.
