Servi car rear brake conversion?
Jun 9, 2019
1
1
BASTIAN, Va. USA.
New guy here. I have a chopped 62 servi-car that I have redone, now that it is finally near finished I've discovered that the rear brakes aren't going to cut it. It has a mechanical brae rear diff. Does anyone know of a good way to convert to disc brakes? Or even hydraulic drums that work decent? Thanks for any help
Welcome to TT Jim.
There are a few threads on Servi~Car rear brake conversions on here. Simply do a search in the upper right corner, and you'll see what others have done.
Good luck...
welcome aboard Jim that is going to be a custom change I bet. GOOD LUCK
Jim, did you ever receive any help with this disc brake conversion?
I have done this with the servicar rearend that came with the hydraulic drum brakes. Turned out to be a fantastic advantage over the stock. Not only that, all brakes front and rear were operated with a handlebar master cylinder!
Cline
