Searching, Stallion forums only
Sep 19, 2017
133
17
Clinton Township, MI
Greg
Hi, I know this might be a dumb question, but is there any way to search just inside of the Stallion forum instead of ending up getting results from the entire Trike Talk forum?
Speaking hypothetically suppose I owned a Stallion now I have a Tri-Glide so now I only look at the Triglide form but yet I have information on the Stallion from owning one that just might help you and others with your/their problem ...I always thought that the more results you get from all sources the better you will be informed/helped ...?
I have specific questions related to the Stallion only and would like to see if there are the same questions out there instead of just asking them all over again.
Every time I try to do a search I end up searching the entire site instead of just looking through the stallion section only.
Yes, go to Advanced Search, then scroll down to Stallion Forum.
I find it easy to do this to get to the Stallion forum:
Look above
Hit FORUMS
Scroll down to Stallion Trikes
Hope this helps...
I'm not sure what your talking about, If I go to advanced search I don't understand here to find the stallion forum from there? do I click on something in there so I can scroll to the stallion forum? Do it for yourself and tell me exactly how you're doing it?
Go to home page........Click on Forums......Scroll down to Stallion Forums...
Easy Peasy.....:Shrug:...
Greg actually all the answers are correct. The procedure depends on if you are starting your advanced search from the Site home page or from the Stallion forum home page.
Bottom line here is you got the answer that will work for you.
Enjoy your search.
mudrock
