Anyone put satellite radio on the Stallion? How hard is it and what's the best brand?
I had one on mine when I bought it. Never used it, so I took it off. It was mounted to the dash to the left of the steering column. It was wired into the fuse block with a wire running to the back and plugged into the radio. It even had a remote. It's in the tool box. I can get a name, if you want.
I just went out and looked, it's a Delphi Skyfi3.
I installed a XM add on and it runs thru the aux plug on the front of the radio. If I had to do over, I would have changed out the radio and remote on the dash to a radio with XM installed. So now I have to put the radio on a FM channel that is not being used which is OK for local use but, when on the road that channel might be in use which over rides the XM and is a pain. Some of the newer radios can use the XM tuner you can get at Best Buy, but mine was not compatible.
Tomg
Try setting your FM on 88.3 that works just about everywhere ThumbUp
