Hello all you trikers,, I have a 2002 roadhawk with the automatic transmission, the shifter handle rod is bent,, so the reverse lock out will not work, real easy to shift into reverse while going down the road, and that would not be good on the transmission, Does anyone know what shifter assambly was used on these machines? Tried calling roadsmith it in Minnesota, no help, would not return my call. Did not want to screw this one up before I knew what it was in case I need a replacment. Thks for any guidance you may have.:Shrug:
