Riser Kit on raked Trike
Jul 8, 2010
36
Montevideo, MN
I would like to put a set of pull-back risers on my Trike. It is a 2005 GL1800/Roadsmith with the rake kit installed on it. When I look at the top cover on the handle bars , it looks like it is just about ready to start rubbing against the meter panel above it. I am concerned that if I installed the pull-back risers, they will not clear the meter panel. Has any-one tried something like this? Thanks for any feed-back.
Lee
I use the MBL Narrow Risers on my 1800, and it does hit the back of the panel a little on full turns, but I haven't worried about it.
Bought a rake to pull back the handlebars and found out they
could not be installed with the triple tree 6 degree rake due to
the upper forks being now to large.
i have a 2004 shadow 750 trike.
I have a 2006 GL1800 RoadSmith. Prior to converting I had installed the Kuryakin Risers. No problems with installing the rake kit my installer ordered from RoadSmith. Everything works fine.
Will the same riser kit work on a 1500, I have a 93 & really need to bring back the bars closer to me. I have been looking & can't seem to find any for the 1500. Thanks Bill
Dragon warrior
