Right Side Tire Wearing Faster
Welcome To Trike-Talk, Craig :wave4:A little more info might be helpful....
Again, Welcome..To the Gang...:clapping:
Most turns made under start out mode, like from a dead stop in first gear, sometimes in a hurry, into traffic, etc ... are sharper right turns, ..... even if not spinning, it wears the RR more. as weight shifts to the left side.
Unless the rear is a locker or posi or limited slip differential (not likely in a trike) ... then it's what is referred to as an "open differential". Just like a car with an open differential, the tire with least traction will limit power applied to the ground as it will spin first. While in a hard right under power, weight shift, etc, the inside right drive tire will rub it's tread against the pavement and wear.
https://en.wikipedia.org/wiki/Differential_(mechanical_device)
I have a 2006 Honda Goldwing GL1800 with a Champion trike conversion. For some reason the right side tire is wearing much faster than the left. Any idea why that would be?
On most vehicles, right side tires wear faster. There are a few reasons this happens. Right tire rolls on rougher pavement. Rougher pavement wear on tread segments more so then smooth pavement does, but it also causes less traction and more spinouts on the right rear tire. When braking, the RR is more likely to loose traction and lockup. In addition, on u-turns the RR tire travel a longer path. On cars and light trucks, faster right wear is a one of several reasons why tires are rotated. So long as your trike tires are non-directional, there is nothing wrong with rotating yours from side to side every 5k, and don't forget to have them rebalanced then too.
Jumping on GoldWingrGreg's tire rotation suggestion, if you do have directional tires and notice the tire on one side is wearing more than the other, to even out wear you can have them taken off and remounted on the opposite wheel.
You will also notice the "Right Tire" may lose 1 or 2lb. tire pressure compared to the Left Tire over the course of the riding season.
wzejda
