Ride-On
Oct 11, 2010
117
7
La Vernia, TX
Chuck
I have just had to change my front tire So here is my ?.
I have the centramatic wheel balancing plates on my front wheel and they have done a fantastic job. BUT with being on the road and some roads not so good i am thinking of putting Ride-on sealant in my tire. Its suppose to help stop any leaks as well as balance the tire.
Has anyone out there ever used Ride-on in conjunction with centramatic wheel balancers. In theory they should work together as one is internal of the tire and the other external. BUT WITh things moving i concern myself that they will want to counteract the other and neither work.
Not with but, instead of!
Works great as a balancer-can't attest to punctures as I have yet to have one in any of the tires I've put ride on in. The claim is up to 1/4" punctures and only works in the "working part" of the tread. I have never had a problem w/it. However, be advised, I am waiting on a report from RideOn on samples sent to them from another on a different board. We have at least 3 reports of RideOn clumping in tires.
My thoughts are 3 problems:
1. All 3 reports are from "hot" temp areas of the country. Temp related defect.
2. Moisture inside the tire-maybe from excessive amounts of tire lube use when mounting new tires.
3. A bad batch of material got released to the public.
We shall see what RideOn has to say!
zigzag3227
