RG3- Need to change rear wheel offset or add wheel stud leng
agapsdiver
Jan 25, 2023
31
76
Austin, TX
Steve
RG3- Need to change rear wheel offset or add wheel stud length.
Wheels are the RG3 18x7.00J
Need to either get new wheels with 1.5 in. more negative offset (to push tire out further)
or add 1.5 in. to wheel studs and install 1.5" spacer to move tire out.
Any suggestions would be appreciated.
Where to acquire parts greatly appreciated.
I have bought a few sets of wheel spacers on eBay, they bolt on to your studs & have studs that bolt to your wheels. You need to know the bolt pattern & the diameter of the axle were the wheel goes over it.
I have a bought a few sets of wheel spacers on eBay, they bolt on to your studs & have studs that bolt to your wheels. You need to know the bolt pattern & the diameter of the axle were the wheel goes over it.
Thanks.. found a pair for about $60. Try these out first before spending a couple thousand for wheels.
Dragon warrior
