Removing Tglide fenders
Phu Cat
2250+ Posts
Oct 4, 2011
2,371
1,831
Ocala, FL
Jim
Had the misfortune to have a friend scratch a fender. He apologized immediately and offered to pay to repair it. The paint repair, except for the two stripes near the wheel opening is only $275. However, the 2 quarts of HD paint is ONLY $600.91.
The fun part came when trying to take the fender off. After getting the wheel off, the fender is held on with 6 torx bolts. Being inside the fender they are kind of awkward to get to, not to mention, very, very tight. Harley intended for these not to come loose accidentally. Even once you have them broken loose they are still VERY hard to turn until they are almost all the way out. As I said, these aren't going to come loose accidentally. I stripped two of the bolt heads out and had to grind them off as they are too hard to drill out. Your ratchet MUST stay exactly square over the bolt head or the bolt head will strip. And as you become fatigued, allowing the ratchet to get off square gets easy especially when you're working with an extension. If you have or can borrow an impact wrench that will fit under the fender (good luck there) that might make the job easier. I just wonder how the shop guys do it?
Not sure if this is a justified complaint, but it seems like the holes for the torx fitting in the bolt heads weren't as deep as they could have been. Never had trouble stripping them out before. But not being able to see what you're working with adds to the skill level necessary.
PC
Had the misfortune to have a friend scratch a fender. He apologized immediately and offered to pay to repair it. The paint repair, except for the tho stripes near the wheel opening is only $275. However, the 2 quarts of HD paint is ONLY $600.91.
The fun part came when trying to take the fender off. After getting the wheel off, the fender is held on with 6 torx bolts. Being inside the fender they are kind of awkward to get to, not to mention, very, very tight. Harley intended for these not to come loose accidentally. Even once you have them broken loose they are still VERY hard to turn until they are almost all the way out. As I said, these aren't going to come loose accidentally. I stripped two of the bolt heads out and had to grind them off as they are too hard to drill out. Your ratchet MUST stay exactly square over the bolt head or the bolt head will strip. And as you become fatigued, allowing the ratchet to get off square gets easy. If you have or can borrow an impact wrench that will fit under the fender (good luck there) that might make the job easier. I just wonder how the shop guys do it?
PC
Most use a cordless hammer drill/driver with the lithium battery, Small enough to get into any spot, And the hammer action will loosen any bolt with very little effort ThumbUp
It sure would have been worth $100 to save all that aggravation! Six years ago I gave away all my air tools when down sizing for retirement. Ya probably know how that goes. I'm slowly replacing all that stuff. Like a hammer drill. Oh well, maybe I've saved someone else some grief.
PC
The fun part came when trying to take the fender off. After getting the wheel off, the fender is held on with 6 torx bolts. Being inside the fender they are kind of awkward to get to, not to mention, very, very tight. Harley intended for these not to come loose accidentally. Even once you have them broken loose they are still VERY hard to turn until they are almost all the way out. Your ratchet MUST stay exactly square over the bolt head or the bolt head will strip. And as you become fatigued, allowing the ratchet to get off square gets easy especially when you're working with an extension. If you have or can borrow an impact wrench that will fit under the fender (good luck there) that might make the job easier. I just wonder how the shop guys do it?
PC
I don't know what kind of thread locker Harley uses, but I call it God Snot because it has the Grip of God. I Had to borrow a cordless 3/8" Snap-On impact to remove the bolts that hold the floorboards on when I installed the DK 1" extensions. Two of the allen bolts were in there so tight I almost burnt up the $400 impact gun.
And I know what you mean about being exactly square on their bolts. It is probably due to the fact that Harley bolts (on left) are rounded on the top edge. Don't know why, but it does make it a chore to remove or install accessories, especially in the many tight spots that are on a Tri-Glide.
I also would love to see pics of the fenderless Tri.
[''Yellow''.......... ]
Loctite # 201 Yellow, It's put on dry, almost like wax Then when the bolt is threaded in' the threads releases a curing agent... ...
You are going to find it easier to modify the OEM fenders I think. Mainly because of where the fender sits on the body in relation to the wheel & bolts in the body.
Get some fenders off EBay used. You might have to repair the fender to use it, but they are usually cheap. They also have aftermarket new fenders there.
http://www.ebay.com/itm/Used-Original-Harley-Tri-Glide-Fender-Set-NO-Cracks-NOTHING-Broken-Custom-U-669-/361413095006?hash=item5425e62e5e:g:egMAAOSwgQ9VqbOx&vxp=mtr
or
[url]http://www.ebay.com/itm/Harley-Davidson-Rear-Fender-Right-Hand-FLRT-Freewheeler-Amber-Whiskey-59500176-/191569327038?hash=item2c9a6bf3be:m:mEdRsu10yFqG_udCCedMlmA&vxp=mtr
[/URL]
While it might be a pain to remove those bolts without an impact wrench, be aware of the problem you can create when the high power of the impact wrench brakes the nut (threads) loose in the fender before you get the bolt out.
You just trashed the fender unless you know a way to repair the fender & fiberglass.
If you run into Loctite holding the bolt or nut use a bit of heat to loosen the Loctite. Like heating directly with a flame, or if the flame might cause problems try heating a piece of steel & holding it against the problem. Loctite is a form of plastic & will melt.
Many times the threaded portion is formed to be a lock-nut type & loctite isn't the problem. Then sometimes some knotthead decides it would hold better if they put loctite with the lock-nut......
I use a simple butane torch lighter (less than $4 at Walmart) to heat up the bolts before removing. About 20 seconds will heat up the bolt and soften the locking agent. I use it quite regularly working on Harleys.
Bob :Dorag:
mudrock
