Removing tank badging
Welcome. I have heard of using a strong fishing line, wrap in around a couple small pieces of wood and use it to slide behind the badge & saw through the adhesive slowly. You may need some GooGone to remove the remaining adhesive residue.
Good luck and let us know how it works out.
Unless the bike is relatively new or is black, you'll likely regret removing the badge(s), as the surrounding paint will be noticeably faded vs what's protected from UV under the badge. In other words you might find it needs repaint no matter how careful you are in removing the badge?
Just something to ponder...:Shrug:
The idea mentioned of using fishing line or another "soft" non-metallic, like substance, to carefully "saw" it off is going to be your best way without scratching the clear or base paint. Good luck.
Use dental floss in a sawing motion,keep it against the badge and not the tank then use goo gone to remove the remaining tape.
shawn.s.prescher
