Removing a Hannigan body
Oct 5, 2011
183
28
West Bloomfield, MI
Jay
I'm looking for any pointers on removing the Hannigan body from my 08 RSV, whats the best and easiest method ?
I am going to fabricate an auxiliary fuel tank and trailer hitch for it over the off season. I am hoping to be able to make a tank with more capacity than what Hannigan offers. I was thinking that maybe I could use a RSV tank from a wrecked bike and mount it under there, another 6 gallons easily done, only thing to mod would be the filler neck and a way to mount it.
Good luck with adding the extra gas tank, not much room under there,grinn.[put it in the trunk] Man, how much more gas you need?
As of now I don't have an aux. tank under there and being retired I don't really want to throw 700+ $ at a gas tank, I'd rather use those $ for traveling money or other upgrades.
I have looked at your pics and although they help it's still hard to judge weather or not there's room to put the tank under there. Our trike frame does not have the tank mount tabs from the factory.
http://www.triketalk.com/forum/members/berngren-albums-trike-assembly.html[/QUOTE]
Since I'll be putting in a tank of as yet undetermined origin under there, I'll aim for the gas filler to be on the left side since that's normally where I am when fueling the bike. Thanks for the pic link.
http://www.triketalk.com/forum/members/berngren-albums-trike-completed-10-08-2011.html[/QUOTE]
The body it's self only has 4 bolts holding it on, all the work is in removing everything else.
Seats
grab handles
Antenna's
trunk
Body
Sorry didn't get step by step pictures. :Shrug:
Here we go :) sound right?
To get the body off there are 6 brackets attaching it to the frame. It is fairly easy to do but it will take some time. Hannigan put everthing together with plug connections so all you have to do is unplug, unbolt and lift it off so it keeps things simple.
Here is a list to get the body off:
1. remove both seats
2. unplug wiring connections under passenger seat
3. remove 6 bolts in bottom of tour pack trunk
4. lift off trunk as a unit, i.e. trunk and armrests are still attached
5. remove 4 CB mounting bolts, unplug antenna and remove CB unit
6. remove antenna brackets ( I don't use antennas )
7. remove passenger grab bars 10mm bolt on top and 5mm allen wrench, you have to go in through the hole where the trunk was to get to the allen bolt
8. remove passenger floorboards, 5mm allen head
9. unplug wiring harness going to the rear lights, it runs back along the frame
10. undo the 6 brackets and it should lift free pretty easy with 2 people
Think I'll pass......... ;)
Special Special TOP SECRET Project... :Excited:
gatta get that body off, been three years now...
oh------ BTW you have stainless steel rotors if your trike
was made after 2011. that is a good thing..ThumbUp
Leo , the whole trike is up in the air now. have the tour pack off and the seats , today should be the front fairing and the tank. then start the top secret project. tires are off again lol ---ohhh and the body should be today or tomorrow ThumbUp
This should be done by the time you get back from Florida :D
I am off all next week,Yippy Skippy !:wave4:
Jeff
snowking1979
