Remote Start 2016 Wing/CSC kit
Anybody know the sequence of task to activate my Remote Start 2016 Wing/CSC kit. I was not able to get this to work on my trike as of yet
The 1800 has a remote start feature that utilizes the remote key fob. Once it is
programmed it works really well. Nice for those of us in the colder climates,
the bike will be warmed up when I get to it. I won’t have to sit there and warm
it up so it doesn’t stumble as I pull away. The mechanic said that Honda was planning
on having it as a feature but with everyone being so lawsuit happy they backed
away from having it in case a sensor switch went bad or something and allowed
the bike to
start in gear. (damned lawyers ruin everything) So, instead
it is an “unsupported feature”. There is no warranty coverage on this feature,
officially it doesn’t exist. Sort of like the opening ceremony option.
Anyway, he did mine for me but I wrote down the program sequence to pass along.
Here it is….
With the key in the LOCKED position and the trunk open, press the CALL button
on the
remote. When the horn sounds press UNLOCK.. Immediately
press CALL again. When the horn sounds hit UNLOCK. Hit CALL one more time and
as soon as the horn sounds, latch (close) the trunk and within 3 seconds turn
the key to the ON position.
When correctly completed, the CALL button becomes the
REMOTE START button. Resetting the ECU
or disconnecting the battery resets the CALL button to its previous function
and the process will need to be repeated to make it work again.
The bike must be on the center stand in neutral and the fork must be locked for
this feature to work. Once the bike is running, you must insert your key and
turn the ignition switch to ON before you take the bike off the center stand or
it will immediately kill.
View attachment The 1800 has a remote start feature that utilizes the remote key fob.pdf
Ron A
