I have a 2008 GL 1800 with a CSC Cobra Trike kit. I have checked the clutch switch and side stand switch and both are good. Still will not start in gear with clutch pulled. What am I overlooking?
There are actually 2 bushings on a clutch lever. The one posted above and the other is what the mounting bolt goes through. If you have to wiggle the lever to get it to start in gear, then it is definitely the second bushing is wearing out and allowing too much play. You should not be able to wiggle the lever at all or very little. There is a kit by DHS Racing to punch out the old bushing and the kit comes with 2 bushings. It's not very expensive at $20 on ebay. I gave it a try and for me it didnt work out to well. I ended up just buying a new OEM clutch lever, also on ebay for $33. I should have just done that from the start. Took care of all my clutch lever issues and no more wiggle.
If the switch is good, check the lever for a worn bushing.
