Crank but no start
Ol' Man Jeb
1750+ Posts
Sep 8, 2013
1,865
899
Newton, KS
Jeb
2008 Goldwing/Roadsmith cranks just like it came off the showroom floor but won't start. I'm halfway to my wits end but I still have a few hairs left. Sorry for being so ignert.
One thing that may be helpful is to crank throttle all the way open and push starter button for about 10 secs and see if the FI light starts flashing codes. Pay attention if it does and count the flashes. Long flashes are 10's and short flashes are 1's. For example, 2 long flashes followed by 5 short flashes equals 25. Hopefully it will throw some kind of code that may help pinpoint the problem.
Also how old is the battery? I know these bikes do strange things when battery gets low even though it may still crank.
Battery is bran spankin' new. Got it from local dealer about 2 hrs ago.
i've been trying since spring to get this puppy on the road. Due to wifes illness, I have limited opportunities for maintenance.
It might help if you provided some additional details. Based on your original note, I wrongfully assumed that this was something that just happened.
So, how long has it been since you had this running. If a long period, you may now have some bad gas in the tank.
Last winter was the last time it ran. Been on a helper till spring. Just purchased new battery today. I'll get fresh gas tomorrow.
Ima get some gas tomorrow. There's only 2 forks in the drawer and they both have tines missing, so I'm at a slight disadvantage maintainence wise.
What kind of details would be helpful? It was running up till I put it away for the 2023 winter. It was on battery tender all winter. I came out this spring and the battery was flatter'n a ducks instep.
Did you put gas stabilizer in the gas when you stored it running it to get the mix into the system? If not then there is a good possibility that you have some varnish in the system blocking the flow. I'm not familiar with the Goldwing fuel system, buy we have a couple of very knowledgeable members that might help. Give them a chance to see this thread. good luck
Put fresh gas this morning, still no start. Indicator light for neutral does not come on. Today, I hear a "clunk" when start switch engaged before it turns over, then the next try I get nothing. This did not occur yesterday. Normally, it always started first crank. I want to thank you all for trying to bail me out. I prolly shouldn't even own it.
Well, at least I thought I did. I usually do.
You may have to charge the battery back up. Sounds like you have run it down trying to get it started. Starters draw a lot of current. It will run a full charged battery down quick.
And I thought my troubles were just beginning. Thank you for your input. I need a break anyway.
Seems like you added an additional symptom - neutral light does not come on.
OK, you now have fresh gas. Charge the battery since all of the cranks may have drained it.
Next, go to the reverse lever - pull it up and down - make sure it is disengaged. Now, check to see if you have the neutral light.
If so, jump on the bike, turn the key - make sure the kill switch is off. Hold the clutch and hit the starter.
Good luck
Your 08 Goldwing is fuel injected so a lot less chance of having fuel/gum issues than if it was an older carbureted model. I'd be looking at electrical gremlins. Things like stuck micro switches, rodent infestation and damage to wiring. But first, give your bike (and yourself) a break and fully recharge your new battery. Advice from cycle7447 is good except you have a reverse button instead of the older lever system. Check all your micro switches in the brake and clutch systems for proper operation. You need to get the neutral light back on. Could be the bike got slipped into gear. If that's the case and if your clutch and brake switches are malfunctioning you will get a no start condition, even when stepping on the brake and pulling in the clutch. I've seen instances when finding neutral on a Goldwing can be tough. Sometimes need to get pressure off a locked-up transmission by rocking back and forth. Have patience and you'll find the issue. Good luck and keep us posted..... Jim
Good luck
Another symptom? Someone mentioned the F1 light which comes on momentarily along with oil light and both go out when starter switch engaged.
I shifted until I could manually push the bike into the driveway by hand. I have better access to it there anyway. Hooked it up to the Battery Tender Junior and now waiting for the green light to cme on and taking a break. Thanks.
Drained gas tank, put fresh gas and charged battery, checked all the fuses still no joy. In the interim, relocated to Newton Ks, where haven't found anyone to work on it. My next try is to find a U-Haul to Wichita to a Goldwing dealer. Doesn't appear it'll run this year. Obviously, a mechanic I'm not!! Appears, the deficate hit the proverbial fan. BTW, I'm married to Calamity Jane.
just an off beat thought.
I'm a Harley guy so I maybe off base. Don't the Honda's have a switch that will not let the bike start if the kick stand is down? If so when they did the conversion they would bypass this some how. If that bypass failed?
Not so off beat, good thought worth checking, thanks
dhinzman1
