Has anyone had the brake recall done and what did they do?
The secondary and rear master cylinders are replaced and a complete brake fluid flush/replacement is performed.Has anyone had the brake recall done and what did they do?
If what I stated above was not done, your dealer did not perform the latest recall and you may not be "good to go":AGGHH:Took mine in yesterday and they said it was ok,, nothing to change or fix. I'm good to go..
What's with all the brake recalls in general? It's not just Honda or Harley either. Several others have recalls with hydraulic brakes for some reason. Has China entered the brake market now too?![]()
I believe that poor maintenance has contributed to master cylinder failure. The claim is that old contaminated brake fluid breaks down the metal causing failure.
Interesting! Are you sure it was the ADV and not the secondary master cylinder?Had mine done yesterday. They replaced the rear master cylinder and the anti-dive on the front. It took them 2.7 hours according to the paperwork I got. They warned me that they didn't think Honda was allowing enough time for doing an update on a bike that had a trike kit but they said it went well and there wasn't any additional cost to me.
Everything works great from the ride testing I've done so far today.
BTW, doesn't matter if the secondary master cylinder is capped off(brakes unlinked, front to rear) conversion companies are still recommending replacement under the recall.
so just a simple question,,,, 100% of all the trikes are under recall?? (the following is from roadsmiths website) Does this recall affect Roadsmith HT/HTS1800 (triked GL1800)?
During installation of Roadsmith conversion kits, the SMC on the motorcycle is disabled. Honda’s
repair procedure states: If the vehicles’ secondary master cylinder (SMC) is removed, or the SMC
has no brake fluid flow or connections, this recall does not apply. By disabling the SMC during the conversion process, there is no mechanical or fluid flow link between the SMC and rear master cylinder on Roadsmith triked GL1800 motorcycles.
