just had my right mirror pulled off here in mexico. Is there a secret or preferred method for getting it snapped back on? Doesn't look like any damage really. Thanks for any hints. Terry
Ed, the next time that happens . . . consider a plastic tie like Tom indicated. I had to pull the mirror off when replacing the side panel and "threaded" a tie thru/around the "guts" of the mirror to the inside panel. Snug up tightly, and you should be good to go.My left mirror has come loose several times, mostly when I'm shutting the hood or hit a big whole in the road:AGGHH:. I start on the back pin and with a little pressure the front two snap right in.
