HD calls it the rear fork assembly, I call it the rear swing arm.
While installing the oil filter relocation kit, the left side swing arm cover must be removed as to the filter mount is secured there. Upon reinstal, the bolts did not line up, as the tit holds the rubber mount from moving, it twisted. Also the shaft moves around in the pivit hole. There was a small amount of what seemed to be plastic under the cover. Anyone know if the bushing is shot? And can the rubber mount be spun as to re align the support tit? Sorry no pix but if needed can be posted.
