Question about rear shocks with Variable Sway Bar Control Optionn
My conversion (Goldwing) was done in 2009 with IRS and the variable sway bar option. I took off a rear tire today and did not see any way to adjust the shocks. Does the variable sway bar take the place of adjustable shocks?
Thanks.
Dave
Dave,
The rear shocks are only adjustable by tightening the spring tension. Increasing the spring tension will raise the trike up and you need to be careful to make this adjustment evenly on both side. Raising the trike with this suspension will alter the rear wheel camber and change or cause tire wear.
dhinzman1
