Oil Filters
Guess my question was a little muddled -- <br />
<br />
If you change your own oil and if you do not use a honda filter -- what brand and oil filter # do you use?? What can I buy at Wally World, Autozone or similar place that will fit?? <br />
Thanks, Rick
Below are oil filters considered direct replacements for the Goldwing GL1800.<br /><br />
<font color="RoyalBlue">Honda says they only recognize Honda filter for use on the GL1800.</font><br /><br />
<br /><br />
• Purolator Pure One PL14612, about $6.00<br /><br />
<br /><br />
• <span class="highlight">Mobil</span> M1-108, about $12.<br /><br />
Made by Champion<br /><br />
<br /><br />
• Bosch 3300, about $6.<br /><br />
<br /><br />
• Wal-Mart SuperTech ST6607<br /><br />
<br /><br />
• NAPA Gold 1365<br /><br />
<br /><br />
• STP S-02876
I tried installing the ST-7317 at Wall Mart and I could barely get it in. It is an extremely tight fit and almost imposible to get out. :no:
<div class="bbcode_container"><br />
<div class="bbcode_quote"><br />
<div class="quote_container"><br />
<div class="bbcode_quote_container"></div><br />
<br />
<div class="bbcode_postedby"><br />
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>trikeleader</strong><br />
<a href="showthread.php?p=72746#post72746" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a><br />
</div><br />
<div class="message">Below are oil filters considered direct replacements for the Goldwing GL1800.<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
• STP S-02876</div><br />
<br />
</div><br />
</div><br />
</div>Thanks very much -- exactly what i was looking for<img src="images/smilies/smiley-score010.gif" border="0" alt="" title="10" class="inlineimg" />
The same filters used with regular oil can be used with synthetic oils. Filtering of the oil has no bearing on the type of oil used. I use NAPA Gold 1365 with synthetic oil. The oil I use is the Rotella synthetic in the blue container with the blue cap. That oil is JASO approved.
<a href="showthread.php?p=72820#post72820" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">The same filters used with regular oil can be used with synthetic oils. Filtering of the oil has no bearing on the type of oil used. I use NAPA Gold 1365 with synthetic oil. The oil I use is the Rotella synthetic in the blue container with the blue cap. That oil is JASO approved.</div>
</div>
</div>
</div>Two questions:<br />
<br />
1. How many miles do you run before changing synthetic oil and filter?<br />
<br />
2. What is JASO?<br />
<br />
(make that 3 questions)<br />
<br />
3. Do you consider the Rotella as good as or better than <span class="highlight">Mobil</span> 1 motorcycle oil or Amsoil?
For the 1st question, I run about 6000 miles on synthetic oil between changes.<br />
That is about 2 changes a season. JASO is the Japaneese rating on oil that Honda requires because the engine and transmission shares the same oil.<br />
I buy Rotella because I can get it a Walmart and it is cheaper than <span class="highlight">Mobil</span> One or Amziol. They are all good, but be sure to look at the back of the container and check the ratings to see that JASO is listed.
<a href="showthread.php?p=72824#post72824" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">For the 1st question, I run about 6000 miles on synthetic oil between changes.<br />
I buy Rotella because I can get it a Walmart and it is cheaper than <span class="highlight">Mobil</span> One or Amziol. They are all good, but be sure to look at the back of the container and check the ratings to see that JASO is listed.</div>
</div>
</div>
</div>Thanks, Tom, for that valuable information.
nmbr1soonerfan
