Welcome to TT!ThumbUp
Best thing that could be done to a 2009 or 2010 Tri Glide is the 32 tooth to 30 tooth sprocket change.
I am a technical idiot who has a 2008 Harley Ultra Classic that had a Champion trike conversion done 2 years ago. My beautiful bike is now a power wimp with any headwind or up hills. Like I am lucky to get 65 mph in those conditions. It is a 96 engine with V & H slip on's. In purely laymen terms what can I do so that I can keep up with the pack on rides. I have heard everything from stage 1 to stage 3 kits.. Which one is going to get me to the power I want to keep up with the pack. :gah:
wiredgeorge states what would be the easy answer for someone in your position. The 14 and newer TRI's really solve most of your issues. If you need to stay with what you got which is not bad, you can improve it by changing the drive gearing to 30 tooth trans sprocket and a 70 tooth rear sprocket. If I remember correctly Champion recommended the rear sprocket be a 70 when the kit was installed. The trans sprocket might be a 32 I'm not sure. Once you are at 30/70 gearing then install a good low end torque cam like the TTS-100. There are other cam brands similar, but I know that cam is good. Have a good tuner with tune added and you will be good to go. Parts for these suggestions would be just below a grand. This is (just my thoughts) Good luck
So I went to my local Harley Dealer in Dallas and they were more than happy to try to get as much money out of me as possible. Surprise, Surprise:Shrug::Shrug:. Of course they suggested to go with the Screamin Eagle Stage 5 Tire Shredder 110 Kit, dyno tune and keep my Stage 1 kit and Vance and Hines already on the bike. Out the door $6,200!!!. To be honest I did not recently win the lottery:xzqxz:. Their second suggestion was Screamin Eagle 103 Big Bore Kit with S & S cams, dyno tune. Again a big $4200 out the door. Am I wrong in thinking these are both overkill?? Reading the thread here sound like I can get what I am looking for at a lot cheaper price. Thanks for all those who suggested a sprocket change to a 30. Should I just do that and put in a cam and dyno tune and be done with it. Don't wan't to keep going back to the money pit. Would be interested in suggestions that keep it in the budget range of $2,000.![]()
The hard truth for more power = more money spent. You need to be realistic and accept its going to cost you if you choose to go down the rabbit hole. The first rule is know what you want for power before spending the money. If your looking for a bump in what you got now, the cams, cam bearings, sprocket change, ( Possible clutch spring ) tuning module with a dyno tune is your going to be your cheapest costs. Want bigger power, expect to spend more money..... PS, This my advice take for what it is..... Stay away from most dealers. They only know how to swap parts.... not build engines for power
