Here is how I connected my wiring up so I do not have to crawl under the hitch to connect wires or chains.I ended up contacting CSC direct and ordered 2 of their pigtails. The first one I mounted permanently using a round 6 pin vehicle side connector just to the left of the hitch. Since the camper trailer is the main trailer I pull, it made the most sense. I just didn't wire up the center pin. On the CSC, that 6th connection would be a 12v supply. On the camper, the 6th wire is for the brakes. Since I never got around to adding a brake controller on the trike, I just left that 6th wire disconnected. On the second pigtail I ordered, I cut down the wires on the 5-4 converter I also had, connected it to the extra pigtail, and have a small harness that I can use for when I need to haul the cargo trailer. It is short enough where it won't hang and drag on the ground. I just disconnect the permanent 6 pin harness I made and plug in the other 4 pin harness I made.
![DSC00022 Test #1.jpg DSC00022 Test #1.jpg](https://triketalk.com/data/attachments/23/23041-8099e8998985d4893f09e05a75dc7d23.jpg)
![DSC00021 Test #1.jpg DSC00021 Test #1.jpg](https://triketalk.com/data/attachments/23/23045-ade1de8aa341e65a6b3f9b23abac6a0c.jpg)
