have you contacted Champion and ask them?
i have never had any luck contacting them thru email----had to call
Had it on my 2 post lift today, did a 1500 mile inspection.
Fluid is leaking out of rear axel.
Would not think it is normal.
It is on a 2007 yamaha road star
I have never seen that happen before???? How odd... Take it to a dealer and have it looked at. Those are press fit with out a seal at the axle and the housing so in order for the grease to leak out there might be a gap of some sort... when did it start leaking? was there a bump or something hit?
Checked it, after grease was removed. It is a sealed bearing there is leaking.
It is in the center next to to support on right side. The rear axel unit is a sealed one. Not supposed to be serviced.
It would be nice to have a breakdown on it.
"I have never seen that happen before???? How odd... Take it to a dealer and have it looked at. Those are press fit with out a seal at the axle and the housing so in order for the grease to leak out there might be a gap of some sort..."
That excuse was dead miss.
Proberly a cheap bearing from China.
